Twice recently my 06 Honda 225 abruptly cut off completely while running around 5000 rpm. Both times the engine fired right back up and ran fine afterwards. A third occasion the engine seemed to have briefly started to stall (split second) but then continued to run fine. With a toddler on board, this is not safe and I need to get it fixed before anymore family trips.
Prior to this problem I recently serviced most of my fuel system due to a bad HP pump, including draining the entire boat tank, removed VST, dismantled and cleaned VST/HP assembly, flushed all fuel lines with fresh fuel, replaced all fuel filters, replaced HP pump and filter (tested old HP pump and it was definitely bad) I did not clean or service the fuel rails or injectors or the low pressure fuel pump. I intend to replace spark plugs this weekend but I cannot imagine bad plugs would cause the engine to randomly shut down abruptly.
After servicing the fuel system I have used the boat five times- Two short 15 minute cruises and three 1-hour round trips to the fishing spot. Both times the engine cut out were 20-30 minutes into the cruise, while running near-WOT which is about 5300 on my Grady 257. Fortunately everyone on board was holding on to the hand rails so nobody fell over.
Thoughts/recommendations? I really wish there were Honda mechanics in my area, if that were an option I would just take it in for professional evaluation.
