Thanks to hondadude I got my water pump parts ordered and hockeyguy helped me remove the extension case.
I removed the extension case to replace the upper water tube seal.
I noticed that where the upper part of the vertical shaft goes into the motor it's slightly oily.
I'm wondering if I should replace that seal.
Is it part no. 32 Coupling Seal in the attached diagram?
If so, is it as simple as removing part no. 3 Plate and also replacing part no. 4 Band?
I'm not too worried if it just leaks a slight amount of oil.
I don't want to open a can of worms trying to fix it.
It's a backup motor for my bow rider in case the main motor dies.
I only run it for about 1 or 2 hours a year just to see if it runs.
thanks
http://www.boats.net/parts/search/Honda/Outboard Engine/0/BF75B LA/OIL CASE ENGINE COVER/parts.html
thanks
