3-legged-dog
03, bravo iii, Merc. 350 Mag, EFI, 4 port drainage system. Just installed new manifold, spacer, risers. also new water pump assembly.
i have a fresh water tee valve between outdrive and water pump. so i can flush engine.
symptoms;
engine running, water source is muffs on drive high temps above 170 and rising.
engine running, water source is fresh water tee valve, (by pass outdrive) temps around 160 rise a little and drop back down, like tstat opens and closes. holds at 160.
question, does the bravo iii drive have any internal parts or just open water passage thru the drive to the hose at the gimbal housing?
i am getting ready to pull the drive back off and flush water back and forth thru the drive and water system of the engine.
any thoughts on were to look, thanks as always.
symptoms;
