So I've got my share of 70's Evinrude v4's (6 of them). I have noticed that a lot of the times they have broken piston rings. I did some research and found that they are all prone to breaking rings, but ones with "high ring" pistons are especially as likely. I cannot find what a high ring piston is/looks like but I am assuming, and might be wrong, the piston ring is closer to the top than normal? How can I tell if the piston is the high ring design or not?. I also read that if you have the high ring design to fully retarding the full advance timing by 4 degrees to prevent piston ring breakage.
