albemarle_24
"MOTOR IS EAGLE MARINE 350 VOR
"MOTOR IS EAGLE MARINE 350 VORTEC, HAD TIMING SET WRONG, BUT HAVE GOT IT SET RIGHT NOW . 8 DEGRESS BTDC. USE TO RUN OT 60 PSI AT CRUISING SPEED 40 AT IDLE OR TROLLING, BUT NOW IT IDLES AROUND 5O AND RUNS 70 TO 80 WHILE CRUISING, JUST KIND OF WORRIED BECAUSE GUAGE ONLY GOS TO 80 AND I WANT TO MAKE SURE ITS NOT GETTING TO HIGH. ALSO WHEN I UNPLUG THE 12 VOLTS FROM DISTRIBUTOR AFTER SETTING TIMING TO RELEASE ANY ADVANCE, MY MOTER ADVANCES SITTING IN THE DRIVEWAY 10 DEGREES IS THAT NORMAL....THANKS"
