Hello,
2003 5.0L Mercruiser (carb) raw water cooled, alpha 1 gen2 drive.
Changed the thermostat, checked the risers and gasket (replaced), replaced manifolds/risers 2 years ago. Impeller changed 1 yr ago.
When I'm running on plane 3700-3800rpm, the port side of the engine runs hot (confirmed with ir heat gun) it is running @ 200*, starboard side is cool @ 170*, and thermostat housing is @ 180*. Any ideas why one side is running so hot? Boat was running @ 175* in May and June, this just started last week, though port side has always run hotter than starboard, but now engine is running a little warm.
Thank you,
David
Thank you,
David
