Fish-N-Fool
I just bought a nice running older 150 black max to replace the somewhat newer 150 black max that burnt the pistons. The motor I had on it was a XR2 150hp and i believe made in 1985, this motor I'm trying to put on it a 1978 model ser. #5108706. I thought this would be a fairly simple swap but almost everything is different on these models. From the bolt pattern of the motor. to the power trim, but mostly the wiring. I took the wiring harness off my XR2 to use on this one as the boat has a plug for the xr2 motor and this one was hard wired on the boat I took it off of. I have managed to figure out everything, BUT how to turn it off? IT starts off the key and runs great, but when I turn the key off it stays running. Even disconnecting the battery does kill it, so the charging system is working good. Any one know what I need to do to get this to turn on and off with the key? Here is a picture of the wiring where would the black and yellow wires go?
