I installed a new tach and tri
I installed a new tach and trim gauge on my 91 Johnson 70hp. Had some trouble with broken connectors in the control unit plug for the tach harness. I ended up hardwiring the tach harness inside the control unit. Verified proper wire connections several times.
Trim gauge works fine. Set the tach for 6 poles. When I got out on the water the tach seemed to work when I first started the motor. Don't know how accurate it was reading but it seemed to track linearly up to about 3500-4000 rpm then took a huge leap and was bouncing all over the place. I think it even spun all the way around. Tried different pole settings with no improvement.
Besides the possibility of getting a bad tach is there anything else that could cause this? Bad ground? Rectifier going bad? Anything?
Alan
Alan
