I have a 1994 Mariah Talari with 5.0L Mercruiser and Alpha outdrive.
I had gear oil leaking into bilge. Pulled lower unit and it was leaking. My outdrive serial number is OF317539. I replaced oil seal part number 18-0577 (#17 in diagram.
I then pressurized lower unit to 10 lb. and it held pressure until I spun the shaft. Once I stop spinning it holds pressure again.
No other parts show obvious signs of failure. Any suggestions are appreciated.
