pimpintackle
Thank you in advance for any help.
The motor will generally startup pretty strong after a pump or two on the primer bulp and just a little choke at the key.
It will run for about 60 seconds at idle and then die. If you try to give it any more throttle in that first 60 seconds it'll die almost like being air choked.
To me it sounds just like a fuel starve issue.
I have attached three videos.
Video 1 is off a jerry can into the front of the outboard cowling.
https://www.youtube.com/watch?v=3iugZcL_onQ
Video 2 is with a new fuel pump, fuel direct off a jerry can, new fuel filter.
https://www.youtube.com/watch?v=dDBRpP3Vq_E
Video 3 is back to the stock fuel situation from the on board tank and the original fuel filter, but with the replaced fuel pump.
https://www.youtube.com/watch?v=Bhjq40J7mT4
Any advice please?
Any advice please?
