" I was wondering if someone c
" I was wondering if someone can tell me the secret to removing the prop shaft on a 7.5 hp ('75 I think) merc kiekhaffer? I've got everything off, but I need to remove the prop shaft as the shaft seal is bad, it's been leaking lower unit grease, so I took the whole thing apart, but can't get the prop shaft out. Also, when I took the retainer ring out, there was a aluminum o-ring behind it, but no other rubber o-ring. From what I understand there is supposed to be one there, but my question is does it go in front of or behind the alum o-ring?
If all else fails, I can probably take it to a shop and get it done pretty cheap, but if I can I'd like to do it myself.
Thanks!
Ben "
Thanks!
Ben "
