ok here we go . i had starting problems . found out that #1 cylinder CMD was bad and replaced it. now with new one instilled i have still have firing problems with that cylinder . i get shock if i touch the plug wire but if i pull the wire off there is no spark that will jump over to the plug. i switched out the 1 and 2 plug to see if it was a bad plug but it did the same thing. any ideas out there on what is going on. i also put in a new voltage regulator and had no change. i can pull off the # 2 and 3 plug wires and see the spark jump to the plug with out getting shocked but can't even touch the # 1 wire without getting shocked , while wearing rubber gloves i can pull the wire off and there is no spark jumping to the plug i can hear the ticking sound of the spark but can't see any sign of it.
