D
Dave Ervin
Guest
" I have a 1981 inline 6, 115
" I have a 1981 inline 6, 115 HP starts fine, idles fine up to about 10 mph, when I give it the gas it just spudders. It won't get up and go. I rebuiilt the fuel pump hoping this would fix the problem to no avail. I had the motor checked out, compression is good, ignition is good from a mechanic. He wanted the boat for 2 days and I was in the middle of a fishing trip to Alabama, we said no,so we ran on idle speed only. Please any insight would be helpful. I believe the carbs are not getting gas. It idles fine and runs fine up to about 10 mph. When I give it the gas, it cuts in and out, boggs down and the motor will die unless I ease off of the throttle. Also my primer bulb last nite wouldn't hold prime or pressure. I pumped the snot out of it and it finally held pressure with no results of higher speeds. Also there is some gas leaking (carbs) after I shut it down for a while. Is this normal? Is it OK to pull out the carbs and just clean them? What would I use, what is the best way to do this. I am guessing from all of the input that this is where my problem might be. Any suggestions I am on a tight budget.
Thanksl
Dave "
Thanksl
Dave "
