Hello. I need help on my 1977 AQ 130. I have had this boat since new. This spring I rebuilt the head, put in new rings, main bearings, rod bearings and rebuilt the carbs.
The boat runs great if I stay below 4500 rpms, it will go all day. It will pull a skier out of the water great running up to 5500 rpm and after about a minute it starts losing power and then backfires and will die. If I pull the throttle back down it will recover after a few seconds. (as long as I keep the speed down) It has consistantly done this each time I try. This happens just driving or pulling a skier.
I put in a new fuel pump. I checked all the fuel lines for blockage. I checked the fuel tank for blockage. I checked the carb bowl levels. New fuel filters. Changed the coil, new plug wires, new dist cap and points and rotor. Rechecked the valve clearances.
One thing that did happen is the engine overheated on the first day out (I had put in an "new but actually several years old" faulty impeller that disintegrated causing the overheating). This overheating happened after the engine dying thing happened a few times. I took the head off and replaced the head gasket which was affected by this. The next day out the same stalling thing happened. Compression is about 150 straight across.
I don't have any water in the oil or it isn't overheating, running about 160 at idle and 180 going higher speeds. After 35 years this hasn't happened before. The only similar thing that has happened is the carb jets getting some junk in them but when this happened, there was no power from the start.
To me it acts like fuel starvation but the other day the engine just died and investigating this I discovered the wire off the main fuse had fallen off. I tightened all the connections and it actually ran great for an afternoon. Now today I went to the lake and pretty much the same thing. Just won't stay at high rpm for more than about two minutes.I double checked the fuse and coil connections (those stupid push on connections) and even eliminated the fuse with no better results.
Can anyone give me some ideas what to check next or if I may be missing something. Sorry about the long post. Thanks for any help.
