hairdresser100
I have a boat with twin 1997 Honda BF90A carburated Hondas and need help on what seamed like a simple issue. Turning over fast.
When I bought this boat last year it had 3 batteries in it and the stb motor always seamed to have a dead battery. I would charge the batteries and the stb motor would always have just enough cranking power to get it going in the morning ........once warm, it would be fine all day no matter how long I stopped.[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]After watching the very short charge time on the charger, I realized the batteries were not dead. I had them tested and they were ok. Not great but not dead.
So, I replaced the batteries with two (changed from a 3 battery system to a 2battery system) new large batteries and the same thing happened so it wasn't battery related. This past winter I rewired everything the right way sparing no expense. Everything new. I figured I got it....NOT! Same engine turns over real slow on battery one or two then comes to a stop on the 3rd-4th crank. Switch to both batteries so two batteries are now running the starter and again, it sounds like I could have just enough to start it. Batteries and wiring not my issue.
The other motor always turns over very fast, no issues there.[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]I have a parts motor and swapped the started....same thing..slow turn then it stops quickly about the 3rd crank. Does the same on battery 2. Other engine on battery 1 or 2 turn like a champ.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]I wired it correctly, batteries are strong............what would cause the motor to act like a dead battery all the time?? Internal engine parts, magnetic starter switch...... I should pull one spark plug out at a time and check the rate of spin to see if one of the cylinders makes a big difference.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]Last year I did get in a jam where the two charged batteries were not good enough and the motor stopped after 8 turns and was dead. I thought the motor was seizing up so I used a huge screwdriver to rotate the flywheel a little bit from what I assume was the compression stroke, then the starter was able to get a head start and spin past the next compression stroke and start.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]Any clues? The Honda manual didn't really help.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]No fuses blow.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]I do have one bad kill switch. Pull the lanyard off and it still runs. Not sure if that's port or stb though.[/FONT]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]I did a compression test on both motors and got 90 psi in all 8 cylinders. Should be 215 so I assumed by gauge was bad....if not it should spin even faster!!! [/FONT]
[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]THANKS!!![/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
