M
Murat Artan
Guest
" I do not have any repair pla
" I do not have any repair place around here, so I am trying to figure out if the problem with my outboard engine (Johnson model J8RENM, bought in 1992 but almost not used)is trivial enough to be solvable by myself.
When I start the engine, I observe that the cooling water circulation does not work. Although the water-out hole seems to blow out (or rather "spray out") air.
After a short run (10-20 seconds?), the engine shuts itself off. I am hooping that it is due to some sort of fuse system to prevent overheating.
What can the problem be? If it is blocked for water, how come it blows out air?
I really appreciate any help, any tricks, any on-line help internet sites for johnson outboards and the whereabouts of the impeller in the engine, if you suspect the trouble is with it...
The nearest dealer is around 500 km away, I appreciate any help.
Best Regards. "
Best Regards. "
