Jackson Hokanson
1990 40 HP Johnson outboard with oil injection
I'll post a video. I had not taken the boat out in a year and a half and decided I would put some plugs, change the oil out from the stuff the boat had in the reservoir when I bought it to the synthetic XD50 (it was blue verse the red stuff I had in it) recommended by a boat mechanic. I also changed the gear-case oil in the lower end.
I was out a week ago when the warning horn went off in the dash intermittently. I was told it was probably an air bubble that caused a low oil event, but I should probably change the impeller with a water pump kit. I got a water pump rebuild kit off Iboat and it started right up in my drive way and idled and ran for 30-40 minutes (I did end up with an extra bolt). I tried to take the boat to the lake today and I could not get the engine started with the boat in the water. As soon as I got home it started right up in my driveway again, but it started overheating (the solid warning horn came on)
I was thinking I should drop the boot and see it my water pump is holding up, but I am not an experienced outboard mechanic. I can work on cars okay with the help of youtube, but I wanted to see if anyone had any thoughts or suggestions to why a boat would run at home with a hose but not start when submerged???
any thoughts or suggestions?
