Hello,
I bought a Landau Pontoon Boat with a 1999 70 HP Johnson 4 stroke From What I hear it was made by Suzuki) it will start and run rough idle but cuts out when trying to run it out.
The Injectors have been replaced, Plugs and Wires also and now I am looking for other culprits. I was told to check spark and compression (will do that tomorrow) also to check fuel pressure? Where do I hook up the pressure gauge? Also pumping the Bulb while running does not seem to help it run better.
When you turn the key on I can hear the electric Fuel Pump cycle for 3 seconds as the manual says it should.
Is there anyway to hook this motor up to a PC to get Codes? Also if so where do you hook it up and where to get the software???
Thanks for your help.
Wes
Wes
