catfishfinder
Hello Everyone I am from north dakota, New to the site and outboard motors.
I picked up a lund alum boat and a 40hp merc 402. I hooked the water muffs to the motor so it didnt run dry, new gas, a couple plugs ,pulled it a few times it fired up. I noticed right away no water coming out so I assume that the impeller is dried up , I didnt run it for long and the motor started to speed up on its own and the throttle controls do nothing . Every thing is hooked up so I am assuming that the motor has a air leak. It looked like there was oil running down where the cases splits from the top by the flywheel. so I figured crank seal out. I pulled the flywheel today and the seal is dry and clean. I sprayed penetrating oil on the seal and walked away for a half hour or so and it was all still there. Im starting to think that I will have to pull the engine and reseal the case halves. Is this a common problem, or am I just missing something simple. I really appreciate any help, the local shops here dont want to do anything but try sell me a new motor. Thanks all for helping out a rookie.
