"well i got out on the water y
"well i got out on the water yesterday. my merc. 260 w/ 2 bbl rochester carb. would run pretty good, but with a bit of hesitation in acceleration. if i cut it off for more than a few minutes, i would have to pour a bit of gas in the carb to get it going. once running it was ok. it did cut out a few times at idle and didn't seem to run as strong as it used to. i rebuilt the carb. and changed to pertronic elect. ignition., so i expected it to run mch better than it did. also, when it was cold i only got a response from adjusting the idle screws in. when adjusting them out, it didn't make any difference in the idle. even when i screwed them nearly all the way out. but, when the boat was warmed up, i didn't get any response from screwing them in or out. so, i guess i didn't nail the carb. rebuild. it was my first one. i tried to be diligent. what do you think my problem is???"
