Hard starting
Scooby
I have a 4.3 mercruiser. This motor will cold start in my driveway with little problem. Then when I get to the boat ramp it will not start without holding the throttle wide open and cranking the motor for a extended amount of time. I have the same problem after the boat sits for a few hours. I have had it to a shop twice and they say everything is ok. I just rebuilt the carb myself to make sure it was done right. Has anyone else had this problem?
Ayuh,.... Which carb,..??
The 4bbl. carbs are known to leak off into the intake, causin' a flooded start situation if only turned off for a few minutes or hours,...
Then a hard start in the mornin', 'cause the carb is outa gas,...
