The starter of my WD3 engine recently broke down and doesn't work anymore. I am looking into hand-cranking the engine because it is cheaper and might be easier to install/use.
There is a cranking shaft on the engine however I have little room there, so cranking will be hard to do. Do any of you know if there is something I may be able to buy or install at the part the starter usually goes, that I can use to apply enough torque to the flywheel to make the engine start?
Please let me know what I might have to buy or install.
Thanks in advance
L. Vellenga
Thanks in advance
L. Vellenga
