"Hello ,Recently I replaced a
"Hello ,Recently I replaced a forward gear of lower unit because its tooth got ground. Then I put the boat in the lake, start the motor and push the control lever for forward, but it engages to REVERSE, pull the lever for reverse then it goes to FORWARD. What is the problem? The motor is year 78 80HP 4-cyl. Merc. I upgraded a motor from 78' 50HP 4-cyl Merc. That means I still use the same 50HP motor control for 80HP motor. The 50HP motor control does fit to a 80HP motor so I set it up. Is that the problem? Someone Help me,please"
