glastroner
Just noticed gear oil (ide
Just noticed gear oil (identified by smell and color) coming from the weep hole above top refill screw. From what I read in the threads on the subject it is most likely from the seal under the water pump or the shift rod o-ring. I replaced the water pump a couple of years ago so I know how to get in here. Can I replace the suspect seals without removing the prop mechanics and do I need any special tools? Can I pull the shift rod out? Are the water pump seals easily reached? Basic instructions would be greatly appreciated before I get into this...Last thing I need is bunch of bearings rolling all over my floor.
