L
Luc
Guest
" Hy, I have an 18 hp johnson
" Hy, I have an 18 hp johnson 1958. I rebuilt the lower unit, change the 2 coils,2 points,and 2 condeser and rebuilt the carb. The engines runs perfectly at hy speed as well as at low speed while trolling. The only problem is that after trolling for a little while, i see what appears to be gas or oil around it in the water.
What i dont understand is that it runs very well, i checked the lower unit oil and no trace of water and the oil level was fine, the two spark plugs were fine,(light tan) so, what am i missing here.
I use Johnson 2 cycle outboard oil in the right mixtures (50:1). The only thing that i have been told by the dealer that sold me the oil is that since i was using castrol before that i might see thing coming out of the engine like if it was cleaning itself. Can this be what's appening?? Because there is something coming out of the engine and i am tring to stop that. "
