I'm having a fuel starvation issue I'm trying to track down the cause.
My port engine loses RPM after running for 15-20min under load, and the problem gets worse the longer it runs, and increasing the throttle does not result in an increase in RPM. I’ve already changed out the Racor filter had no impact. Both engines feed off the same tank so it isn't the fuel.
If it cools for 30-45min will run normal again for up to 10-15 min then same problem. The longer it runs the worse it gets. This started about 4 hours into an 6 hour/2 day run, and progressively got worse to the point where I was limited to 1200-1500 RPM for the last 10 miles or so of the run.
I haven't had a chance to run it again, so I'm not sure if the problem is worse now immediately or if the engine will again run fine after cooling. My yard mechanic told the work order manager he thinks it may be a bad coil, but I'm not sure how much info was relayed to him to make that assessment.
Any thoughts on candidates? I'm worried that since it takes some time under load for it to crop up, it won't be easy to get a diagnosis from the mechanics who have plenty of other work to do this time of year....
