I have 2000 J 150 VL SSS with a fuel issue. The engine cranks and runs well until it seems to run out of fuel. I can use the manual bulb to pump fuel back into the engine and it will restart and run well for a little while only to die again.
Is there a way to definitively tell if the pump has gone bad?
Second question is whether or not the original fuel pump can be removed and replaced with an auxiliary fuel pump? (I mix the gas and do not use the oil pump so that shouldn't be a problem. All of that was removed by a mechanic years ago. Not sure what all was removed other than the oil reservoir and alarm)
