I have a 90 merc 115 newly rebuilt that runs ok at low rpm's but when you try to go over 3800rpm's it starts to run out of gas. pump the bulb and it runs again and if you come to a stop it will die after starving which makes sense however, I pump the bulb up with the hose off the motor and it holds tight. Could it be the fuel pump cant keep up with the demand? or is the vent perhaps partially plugged. I removed the fuel cap and it did the same thing. Any ideas?
