Hello to all,
I have a 2002 5.7L Mercruiser MAG with 570 hours on it that has oil leaking into the oil crankcase. I had it to the repair shop (Mercruiser dealer) twice and the first time they said #8 injector was bad and fuel line pressure was bypassing the injector at low idle and/or motor stop and getting into crankcase. The second time (within 30 hours or less) for the same issue they said the #2 injector was bad so they again replaced that one. they suggest replacing all of them at one time as I was told they might all be bad. I understand that to some degree but it seems ironic that it is going from one to the next. At the moment I am planning on purchasing the other 6 and replacing them my self. Here's my question. Before I do that is there other ways fuel can get directly into the oil other than through the injectors? I am also wondering if the fuel pressure regulator may be bad and possibly over pressurizing the system and forcing fuel to bypass the injectores? Any thoughts on this or any other things someone might suggest to check? Has anyone had this issue before? I am new to this forum and I am still searching it to see but so far I have not found anything. Thanks in advance, your time is greatly appreciated. -Lenny
