Fresh water leak AQ145A
jeroen
"Good day, when my AQ145A is m
"Good day, when my AQ145A is making about 2000RPM or more than water is pressed out under the cap of the seaweed-filter-house ! What can be the cause for this problem?"
"I had this problem before and
"I had this problem before and tried all sorts of fixes, none of which worked except replace the cap. Be careful - this black plactic sea water strainer is not very strong and when it cracks, you're in for a world of problems with sea water spraying all over everything."
"This will give you an idea of
"This will give you an idea of the cost of replacement parts:
http://www.volvopentastore.com/HEAT_EXCHANGER_WITH_INSTALLATION_COMPONENTS_AQ145 B/dm/cart_id.657400424--category_id.333119--list_time.1212082706--session_id.479 464810--store_id.366--view_id.327053
If the top lip of the housing (12) is not cracked, you may want to either replace or turn upside down the gasket in the cap 22. But if the lip is cracked, you will have to replace the plastic strainer housing."
