chuckhanson
"My boat was not used in 2005
"My boat was not used in 2005 and 2006 due to a heavy travel schedule. You can guess that I have had my hands full getting everything ship-shape again. The remaining problem is that although the port engine runs very smoothly, it is fouling plugs quickly. The last set lasted 5 hours. All of the plugs were uniformly dry with black carbon build up. I have run all of the stale gasoline out and about 100 gallons of fresh through this engine. There is no water in the gasoline. The ignition timing is set at 10 degrees BTDC. I cleaned the flame arrestor with carburetor cleaner 20 hours ago. The starboard engine is not having any problems. It only took one change of spark plugs about 30 hours ago.
Some particulars on the boat, its use follows:
Boat:
* 1984 50 foot Gibson Houseboat, owned since 1988
Use:
* Recreational in fresh water
* 14 years on the Mississippi River and 9 years on the Tennessee River
* Most of the hours run at 1400 to 1800 RPM (I don’t race the Gibson)
Engines:
* Model CH350 454 CID
* Starboard Left Hand and Port Right Hand
* 1160 hours on each
* Raw water cooled
* Carburetors:Rochester Quadra Jet (17082403; Both rebuilt in 2003 by Carburetor Specialist in Alpharetta, GA
* Electronic Ignition
* Electric Fuel Pumps
* Huge Water separators/filters
Any thoughts on what the problem is would be appreciated.
Chuck"
Boat:
Use:
Engines:
* Raw water cooled
Chuck"
