Migillicuty
So I got my 1984 mercury 4.5 lower unit put back together. As I assembled it I made sure I was able to twist the shift shaft and see that the prop shaft would go into forward, neutral and reverse. However, as soon as I got to installing the spanner nut until it bottomed out and lightly snugged it up, It now has no neutral. As I twist the shift shaft it goes from forwards and instantly switches to reverse skipping neutral. So I started to back off the spanner nut until I found a sweet spot where I had forward, neutral and reverse but it made it so the prop shaft had play. Not sure if this is engineered this way but I dont see any other way to make it work? If prop shaft play is normal and you have to fine tune that spanner nut then I guess I stumbled on to the way things are. Just want to make sure this is normal? That little shift cam had the littlest little steps on it making shifting sensitive. When I found that sweet spot it seemed like the prop shaft play was like a 1/8" play total in and out which seems excessive to me?
