Greetings,
I am trying to fix up a 1982 140 HP Evinrude that has sat for seven years and I am running into problems.
I went through the lower unit yesterday. I also cleaned the carbs and the fuel filter. The engine starts and idles OK and water flow looks OK.
Problem 1: The top right (starboard) head gets a lot hotter than the port side heads. The port side runs at what I would consider normal temperature based on my experience with my 35 HP Evinrude. The starboard side is too hot to touch for more than a second.
Problem 2: The bottom port side cylinder has milky fouling on the spark plug which I am sure is water. Also, this cylinder has no observable compression. (I don't have a compression tester at the moment but I am in the process of getting one) I did the "finger in the hole, rotate the flywheel" test and there is virtually no compression in that cylinder.
Problem 3: At fast idle the engine exhausts a lot of smoke. At low idle there is very little visible exhaust.
Problem 4: The engine seems to have a loud knock or rattle, sort of like a piston bearing knock but not like any I have heard before. I am having a hard time isolating the noise, but with the other problems it sounds like it could be piston-related.
I am realizing that this may be more work than I can handle. I am OK down to the head gaskets, but past there is beyond my experience.
Any troubleshooting advice, tips, and all other information is greatly appreciated.
