Happyprinter
Just in need of a few clarifications in trying to narrow down my fuel issue. I disconnected the fuel line between the high side and where it enters the rail. Turned on the key and it seems to be running to that point fine. Replaced the filter in the rail. Lightly blew air thru the rail and fuel seems to be flowing fine. I think it has to be a pressure regulation issue. First question, on the vacuum tank, once it is removed, should you be able to blow air in either of the two hose connection and have it flow? I tried both and no air flow thru either. Second, on the IAB switch, I tested it and it read 40 resistance so it should be fine but there is what looks like a plunger coming out of the bottom of this switch, should it be able to move freely if you put your finger on it and push up? Not sure hw to test the pressure regulator that sits on top of the port side rail but I replaced it las week so I dont think that is the problem. Just trying to trace out all vacuum lines to make sure that is not the problem. When I turned on the key for a few seconds before I started working on it the pressure read 70 today instead of the 90-95 it read last time. Go figure. Thanks
