I have a whaler with a 1985ish mercury mariner 75, 4 cylinder 2 stroke.
It was running great (or at least pretty good) for a couple test runs. But now I am having trouble with it.
When it first started acting up it started surging a bit at high throttle and occasionally dying. Then for a while it would run in gear at ~2-2500rpm but die if I gave it more throttle. Now it will sometimes run at 2k but often just die when I shift it into gear at all, and will always die if give it more throttle.
Throughout this though it revs up fine when not it gear, makes it to 4k-4500+ and sounds fine to an untrained ear. For a while it seemed to be a little slow to rev up all the way, would sit at 3500 for a few seconds and slowly work it’s way up, but now it seems to be going straight there.
My uninformed idea is that is a clogged jet… but would it still be able to make it to 4500 while not in gear if that was the case?
Any help appreciated, thanks in advance.
