New bellows can be a b!tch to install because they want to remain in the retracted position.
With the bellows first attached to the exhaust tube flange and clamped, make yourself a wire harness that will fit around the next to the last accordian inset.
Attach to pull wires to this harness affair.
Lubricate the Intermediate housing bellows flange, and perhaps lube the bead just inside of the bellows.
Wtih the band clamp in position, pull the harness towards AFT and onto the flange.
It won't want to cooperate very well, but this does work.
I rarely see the AQ series exhaust bellows go bad. If this has the back flow prevention flapper, then I do see the flappers go bad.
If your 270 exhaust outlet flapper is good, there's no need for the internal bellows flapper, IMO.
In which case if your old bellows is OK, remove what's left of the internal flapper, and put it back on, and return the new bellows.
