rmcderm313
Hi All,
I'm trying to reconcile my understanding of the concept of "choke" with how my outboard ('87 25HP) is working. Please refer to this diagram of the carburetor in question.
http://www.boats.net/parts/search/M...0/CARBURETOR (MERC 25)(MARINER 25)/parts.html
So I have always understood "choke" to mean choking off air from the carb thereby making the gas/air mix richer. It may also include adding more gas in a priming effort but primarily it implied choking off air.
On this carburetor I can't see any impact pulling out the choke knob would have on air flow. What I'm seeing is that when the choke knob is pulled:
1) It pushes down on the primer assembly (Primer level part #24 on the diagram) on the side of the bowl, which I think by way of the little bellows part inside the primer forces some gas up from the bowl through the main jet into the carb body (venturi?). It only does this once when the choke lever is first pulled out. That makes sense in that it ensures some gas is in the carb, but it doesn't appear to do anything ongoing once the lever is pulled.
2) By way of the idle wire (part #25) it advances the throttle a very small amount which opens the throttle valve (part #2) a bit and sets the carb up to pull a bit more gas through the system.
But again, I don't see any change in air flow based on the use of the choke knob. Am I operating with an older definition of "choke"? Does choke on this motor only have to do with the amount of gas set to be delivered? Airflow doesn't seem to be restricted in this carb at all as there is only one valve, the throttle valve and apparently no air valve at the opposite end of the venturi.
Am I on the right track in thinking that this choke has nothing to do with air flow or is there something else going on here?
Thanks,
Rob
Thanks,
Rob
