Dave Truman
I have an Evinrude fastwin 18, engine cover looks like a 1965, but model number 15016-11022 indicates 1956. Very confusing! I have 24-1 fuel mix, replaced plugs gapped to .030, replaced points gapped to .020, and was ready for this engine to run fine, well, started on first pull, would not smooth out or continue to run unless I metered fuel by pulling and pushing on choke. I could increase rpm by removing cover and manually opening choke butterfly, but, then would hear this occaisional clunk, did not sound good. I assume all is well with ignition system, but, not carb. And that clunk, nor sure what that is about, I assume I'll have new ignition, carb rebuild, then discover a crankcase issue. Any insights on this plethora of issues?????
