I have a 1986 Evinrude model #E4BRHCDE that was getting water in gear case lube. I removed the gear case. Then, after placing the shift lever in the forward position, removed the prop shaft assembly from the gear case. Replaced all seals, orings, shift shaft bushing, and water pump. Before reinstalling the prop shaft assembly into the gear case, are there any tips or advice anyone can offer?
Thanks so much.
Thanks so much.
