tilt the motor fully up...look behind the starboard cylinder and there is a reservoir with a screw in it...you may have to clean it off to find it....do not remove the plug unless the pistons are fully extended...after filling it replace the screw loosely...cycle the motor up and down several times to remove any air from the system...check and if any oil is needed and repeat... tighten the plug and you should be good to go...
if you have to use the manual release then there is a slotted screw on the right hand side as viewed from the back right above the bottom bolt that attached the motor to the boat...do not forget to tighten this when you are thru adding the initial fluid..
which one is that reservoir? is it the one where the screw located to release pressure? boat is in the water,maybe thats why im not able to see it.
p.s thanks for quick response!
