"Hi all, firstly, i am a compl
"Hi all, firstly, i am a complete novice when it comes to boating, Having only just decided to get out on the water (or so i hoped)
I have , as mentioned in subject, a 4HP evinrude (s/n: 48B36E B62774) whether this is model number and serial number i dont know and it tends to pick and choose when it will start and run.
on a cold start, i usually, as expected, have to choke it and it will start (sometimes) and run fine for a few minutes and then the revs will fall until it stalls.
once it has stalled, i would have to pull the rope a few times to sort of prime it and then it MAY start and run for a little while again.
when it starts losing revs, i can get away with opening the throttle a bit to keep her running, but not always sucessfully.
I have replaced fuel line and filter and cleaned float chamber as well as spark plugs which have a good spark on them.
I am dreading having to clean the carbs as i wouldnt know where to start basically and i cannot find a manual for this engine due to not having a model number.
Any ideas anyone?
If possible, would anyone be able to tell me what model it is by the serial number?
Thanks in advance!
Dave"
Any ideas anyone?
Thanks in advance!
Dave"
