chasin_tales
I have a 92 Evinrude 40 hp tiller. I put the muffs on yesteday to winterize it. It was not pumping water. I turned the motor off and backfed water down the tube to see if there was any blockage.
I started it back up and still no water. I could syphon it through but it would not pump on its own. To further complicate the issue, There was a milky type substance coming out from the prop seal area.
I didn't let the engine run long either time, but it ran fine. So my question is what should I check next? Impeller, some type of lower unit seal etc?
Thanks!
Thanks!
