Evinrude30hp
have a 1990 evinrude tracker 30hp that runs fine at idle. take it to the lake and it runs fine in no wake zones. whenever the motor is cold the boat will run fine at full throttle. whenever it runs for 10 minutes and the motor gets hot it will start surging like a cylinder is missing. thought i was getting fuel in my lines/not getting enough fuel. replace primer ball, fuel lines, fuel connections, electric choke, fuel pump, new coils, carb cleaned, spark plugs checked all connections, and its still doing the same problems. tried pumping the primer ball whenever its surging and it doesnt help. bring it back down to idle it runs fine. idle back up surges. starting to get wrapped up in a lot of money and its hard to troubleshoot due to the fact it only does the problem whenever its at full throttle on the lake. has anyone had any similar problems and the solution. thanks
