Hi. I have just bought a boat with an Evinrude 200XP ve200sletc.
Boat ran but was leaking fuel from the throats of some carbs.
I have put new carb kits in all resetting the floats as I went.
Now the engine will start after pumping primer and pushing key, will keep running if key is pressed in. But will run for 10 to 20 seconds after key is let go and then stalls out.
If I pump primer it never gets Rick had like it does if I remove from the motor and plug the end of the line.
What should I try next please?
