Had motor this for the last 15 years. Given great service untill I changed the prop, some 5 years ago. Replaced the prop (9x10) for 9x9 as was listed in the parts diagram as a replacement. Since that time the shear pins (bought thru MarineEngine.com) will shear when I put in reverse, not every time but more often than not. I've tried proper shifting techniques as listed in the manual. I've inspected the new propeller and the machined surfaces that accomodate the shear pin and they are not worn and still have factory produced clean edges. The propeller nut seems tight to the shear pin with no play and the cotter pin fits the hole easily. Any hints would be appreciated.
