the_tassie_devil
What you HAVE to get is longer Dowels to suit the application. They will have to be made as I don't think the longer ones for the length you require are commercially available. And, they NEED to be the exact same diameter, and an interference fit in the Block.
You will notice that there are two alignment Dowels in the block, between the two outer bolt/thread holes and these are used to align the Bellhousing to the Block. So, you need the longer ones to allow the Bellhousing to still align with the Block, no matter how many Spacers you use.
Just using longer bolts isn't going to retain the perfect alignment that is required.
Bruce.
Bruce.
