I just finished replacing a 5.
I just finished replacing a 5.0L(500A) Volvo with a new 5.7L Indmar engine with a 4bbl holley. My old engine was 190 hp (cracked block) and the new one is 315hp at the crank. The outdrive is a volvo DP. I expected great results but got less power and about half the speed. Where is the problem? I have a volvo outdrive (less than 100 hrs(mint) DP. Both engine company and volvo said I didn't need to make any changes in my setup. The motor also has to be choked every time. Cannot start without choking even when warmed up. Ther linkage appears to move the full distance? Feels like half power. Gas is all fresh. (note) plug with wire near top front of intake manifold with wire going no where. no placed to hook up? HELP!! Any ideas??? Thanks
