willbaker13
We went out yesterday morning and rode around for about 20 min and then anchored in a cove for a few hours. Upon leaving the cove (2-3 min) the engine alarm sounded with the yellow check engine light on but there were no alarm codes. I shut the engine off and looked inside. Nothing leaking and water and oil temps/pressure were normal. Started and 2 min later it happened again. It seemed that anytime we went over ~1500 rpm the alarm and light would sound so we limped back home doing about 1000 rpm. Any insight into what would be causing this would be appreciated as I am not sure where to even start. As it's going to the mechanic for another issue later this week, if possible I would like to point him in a direction vs. them starting from scratch and racking up the hours...
Engine is a 2013 VP V8 300-C-A with a DPS-B outdrive.
Thank you
Thank you
