"The pin with the rubber o-rin
"The pin with the rubber o-ring that passes through the electronics module from the top of the inlet housing on the VRO2 pump, is that supposed to be level or pushed down? It seems that if it is level, it will properly sit on the plastic spring loaded switch in the module. Can not locate a diagram detailed enough to tell me. JWB any idea?"
