I just downloaded this off a Magnacor site after a Google search:
[h=2]SOLID CORE CONDUCTOR WIRES[/h]Solid metal (copper, tin-plated copper and/or stainless steel) conductor wires are still used in racing on carbureted engines, but can cause all sorts of running problems if used on vehicles with electronic ignition, fuel injection and engine management systems, particularly if vehicle is driven on the street — and damage to some original equipment and modern aftermarket electronic ignition and engine management systems can occur. Solid metal conductor wires cannot be suppressed to overcome EMI or RFI without the addition of current-reducing resistors at both ends of wires.
Can anyone confirm if Mercruiser wires fall into this category? Let me explain why I'm asking about this. Before taking my boat in for repair by "certified, factory trained Mercruiser technicians" I had put in new ignition wires made specifically for electronic ignition systems which my engine, a merc 3L 140, has. I figured I'd save a couple of bucks as it was something I could do myself easy enough. After they finished the repairs (it took them almost two months) I took the boat out for the first time and within a half hour the engine died and I had to be towed back to the marina. When I checked the engine compartment I noticed that the wires I installed were replaced with Mercruiser noise suppression wires and the distributor cap was also not mine. The cap I had on there was grey and so were the wires I installed. Both were now black (and the wires didn't look or feel new). I was afraid to alienate them so I didn't let on that I knew since I already paid them for a seasonal slip ($1700) and have to live with these people for another two and half months.
So after a few hours the owner of the marina calls me and tells me that the electronic ignition spark sensor was bad and had to be replaced (I guess that's the module itself)....and it'll cost me $87 plus tax in addition to two hours for labor (@$140/hr.) for diagnosis.
All of this occuring after waiting two months to get my boat fixed (mainly having the Alpha One outdrive serviced and a transom re-build, plus other items needing replacement) at a cost of $4992, more than my '86 Four Winns 195 Horizon is worth.
